Activity Forums Adobe After Effects Optical flares and AE Camera question
  • Optical flares and AE Camera question
    Posted by Scott Gaskin on May 27, 2014 at 9:32 pm
    Wondering if anyone can help me with an issue I have using Video Copilots optical flares in AE.
    I have created a scene with a skyscraper and the camera pans from the bottom of the skyscraper to the top. I have placed a lens flare in one of the top windows and want it to stay in that place but I can’t get the flare to stay in that same place. It seems to move independently of the camera. Any ideas? I’m sure its probably something really stupid I’m doing.
    Scott
    Austin Reeves replied 12 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Evan Robinson
    May 27, 2014 at 10:02 pm
    Did you motion track your scene, or is the camera movement the virtual AE camera?
    E. Robinson
  • Chris Brett
    May 27, 2014 at 10:27 pm
    — not 100% sure on this but if using the AE camera think it should be ok if you precompose the flare and the building first — chris —
  • Evan Robinson
    May 28, 2014 at 12:27 am
    I think the problem is you need to motion track your footage in order to have the lens flares stay in place.
    E. Robinson
  • Michael Szalapski
    May 28, 2014 at 1:52 pm
    Did you just place the flare in the scene or is it attached to a light? If it isn’t tracking lights, it’s not going to follow the camera’s movement.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Scott Gaskin
    June 2, 2014 at 9:53 pm
    Hi Evan,
    Didn’t realise I had to motion track. I thought as long as it was set to a 3d layer it would work like any other object!
    Have tried motion tracking since with not great results!
    Cheers
    Scott
  • Scott Gaskin
    June 2, 2014 at 9:55 pm
    Thanks Chris, it seems I need to motion track the footage.
    All the best
    Scott
  • Scott Gaskin
    June 2, 2014 at 9:59 pm
    Hi Michael
    No it wasn’t attached to a light. I did try but found it difficult to place my light where the flare was. I presumed it would just work as other 3d objects do in AE and follow the camera movement.
    Thanks for the suggestion
    Scott
  • Austin Reeves
    June 18, 2014 at 8:30 pm
    You created your 3D sky scraper in AE? In OF you can set the source of your flare to be from a light. If you have multiple lights there is a setting to isolate flares to only come from lights with a certain name. Position the light in your 3D scene. You can also set the flare to be obscured by “walls” of your skyscraper. This should yield far better results than any kind of post animation camera tracking.
    Austin Reeves
    AR&C
    https://www.austinreeves.com
    Production & Post-Production Services
    Washington, DC
