Activity Forums Adobe After Effects Optical flares 3d tracking parenting
  • Optical flares 3d tracking parenting
    Posted by Miloš Homola on May 3, 2012 at 6:23 pm
    Hey I need to advice, how to correctly parent position of plugin Optical flares with some tracking null object (CameraTracker).
    I need to achieve parenting x,y,z position separately and I can see that optical flares has x,y connected so Im stucked here, since I can parent only z position corectly with null object. I need separate x,y position and control it separately.
    Any advice?
    Dane Cannon replied 14 years, 1 month ago 3 Members · 3 Replies
  • Miloš Homola
    May 3, 2012 at 7:16 pm
    never mind I found the way
  • Eric Mc guire
    June 21, 2012 at 1:43 pm
    Maybe you could share how you did it? So you can give help the same way you asked for it? 🙂
  • Dane Cannon
    August 15, 2012 at 8:23 pm
    Under positioning mode, change the source type to 3d, then it will enable you to access the “position z” parameter.
