Activity Forums VEGAS Pro Opinions on MPEG vs AVI Please…
  • Opinions on MPEG vs AVI Please…
    Posted by Videocool on August 6, 2005 at 1:37 am
    Hi there…
    I am wondering…
    I’m using Vegas 6.0, and DVDA 3.0…
    My workflow is this… I have a few hundred clips that I use over and over in different projects that are eventually put on DVD.
    Should I keep them as avi…edit my project (very light editing, just adding clips with one second dissolves) and render anew… for DVD burning?
    Or should I render them as MPEG/ac3 and then add them to DVDA menu authoring… or MPEG/MPEG audio for editing in Vegas and rerender to MPEG/ac3 for single movie authoring?
    Pitfalls???
    Advantages???
    Thanks…
    Steve
    Sony VX-1000, P4, AMD, AMD64 laptop,
    VegasVideo, ReelDVD, DVFILM, Lightwave, Photoshop, 18 years Independent Production
    Seth Bloombaum replied 21 years, 1 month ago 2 Members · 1 Reply
  • Seth Bloombaum
    August 6, 2005 at 2:20 am
    If you can incorporate your “stock” clips and merge them with your other content within DVDA then by all means do so and use them as MPEG-2.
    If they have to be edited with new material then do it in vegas as AVI-DV. Under no circumstances should you bring MPEG-2 into Vegas as editing source if you can possibly avoid it.
    So, we’re talking about a balance of efficient workflow vs. not wanting to edit and recompress MPEG-2 because a second round of compression sacrifices too much image quality.
