Activity › Forums › VEGAS Pro › Operation of the Space Bar
  • Operation of the Space Bar
    Posted by Jonathan Binnie on March 11, 2011 at 7:04 pm
    Hi there,
    Pretty new to Vegas 10 – have come to it from Premier Pro where I am used to the action of the space bar starting and stopping play on the timeline.
    Vegas seems different. It starts play from a point in the timeline, but when I press space to stop, it goes back to where I started play from.
    Can I change it to stay at the point on the timeline where I press the spacebar, rather than have it go back? I am trying to do cuts on the main timeline and this seems counter productive.
    Thanks for your help.
    JMB
    Graham Bernard replied 15 years, 6 months ago 6 Members · 6 Replies
  • Steve Rhoden
    March 11, 2011 at 7:16 pm
    Simply go to “General” in the preferences of Vegas and
    select “Make spacebar and F12 play/pause instead of play/stop”
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
  • Kelly Griffin
    March 11, 2011 at 7:35 pm
    That has driven me nuts, too. Since the beginning of time a spacebar press has been a start/stop toggle!
  • Mike Kujbida
    March 11, 2011 at 7:43 pm
    [Kelly Griffin] “Since the beginning of time a spacebar press has been a start/stop toggle!”
    Kelly, that was in the “old” days 🙂
    Vegas subscribes to the “new paradigm” and, as you’ve discovered, does things VERY differently.
    You need to do like I did when I first started using Vegas and that was to forget everything I knew about running a dpsVelocity.
    It made my life a LOT easier!!
  • Jonathan Binnie
    March 11, 2011 at 10:02 pm
    That’s great – thank you very much.
    JMB
  • Larry Brewer
    March 12, 2011 at 3:10 am
    Options / Preferences / General / Check box> Make spacebar & F12 play/pause instead of play/stop.
    Sony Vegas isn’t all that different than other NLEs, and where it is different, it’s usually better.
  • Graham Bernard
    March 12, 2011 at 3:55 am
    You might also wish to read the Help file along with Preferences. There is a wealth of easy and simple info to be had. You’ve bought Vegas, might as well squeeze out all the juice you’ve invested in.
    Grazie
