Activity Forums Apple Final Cut Pro Legacy Operation FAILED
  • Operation FAILED
    Posted by Bert Delgado on December 14, 2010 at 12:00 am
    Greetings,
    I tried to burn a one hour and fifteen minutes Blu Ray disc using Share, in Final Cut Pro 7
    I clicked on the Compressor button on the Share window and selected the H.264 quality for 90 minutes.
    Started at around 8:30 in the morning. By 7 PM a message indicating that it failed, appeared.
    The Timeline was audio & video rendered prior to starting the Share application.
    Any suggestions on settings for over 1-hr long Blu Ray disc, or why it failed?
    Thanks for info.
    Bert
    Walter Soyka replied 15 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Michael Gissing
    December 14, 2010 at 12:06 am
    I don’t know anyone who recommends using Share. Best practice as espoused here often is to first export a self contained quicktime movie and then bring that into Compressor to make H264 files etc.
    The process of then authoring and burning a bluray will require additional software as DVD Studio Pro doesn’t author bluray.
  • Bert Delgado
    December 14, 2010 at 12:58 am
    Hello again,
    It looks like you are solving all my problems.
    Thanks.
    Be well,
    Bert Delgado
  • Michael Gissing
    December 14, 2010 at 1:49 am
    [Bert Delgado] “It looks like you are solving all my problems.”
    I draw the line at advice on personal relationships. Happy to help in areas of comfort.
  • Walter Soyka
    December 14, 2010 at 2:40 am
    [Michael Gissing] “The process of then authoring and burning a bluray will require additional software as DVD Studio Pro doesn’t author bluray.”
    Compressor 3 does author very rudimentary Blu-ray, but anything more sophisticated than a basic template-driven main menu does require additional software.
    https://documentation.apple.com/en/compressor/usermanual/#chapter=25%26section=3
    Like Michael suggested, I’d export a self-contained movie and bring that to Compressor.
    Walter Soyka
  • Michael Gissing
    December 14, 2010 at 3:00 am
    [Walter Soyka] “Compressor 3 does author very rudimentary Blu-ray,”
    Thanks Walter, good to know for a quick & dirty.
  • Bert Delgado
    December 14, 2010 at 6:21 pm
    Hello Walter,
    I have one additional (and hopefully final question)
    The DVD I would like to burn will not have any menus or anything else except a continuous movie, about 1 hr and 15 minutes long.
    Would compressor handle that after I create the H.264 file?
    I also have a software which I have never used named “Toaster.” Should I use that one?
    Thanks for info.
    Bert
  • Walter Soyka
    December 14, 2010 at 6:28 pm
    [Bert Delgado] “The DVD I would like to burn will not have any menus or anything else except a continuous movie, about 1 hr and 15 minutes long.”
    Do you want to burn a DVD, or a Blu-ray disc?
    [Bert Delgado] “Would compressor handle that after I create the H.264 file? I also have a software which I have never used named “Toaster.” Should I use that one?”
    Read through that link I posted — it describes how to use Job Actions with Compressor to create DVDs or Blu-rays. You can also take a bit of a shortcut by using Compressor > File > New batch from template to set up the compression job and job action in a single step.
    I think Compressor does force a menu on you, but you can set the disc to first-play the content instead of the menu. In other words, it will let you set the job to auto-play your movie when you insert the disc in a Blu-ray player, but it will return to a menu when the movie completes.
    I think that Toast’s Blu-ray authoring is about as limited as Final Cut Studio’s, but I haven’t used it.
    Walter Soyka
