Activity Forums Adobe Encore DVD operating system error: number = 0x00000020????? HELP???
  • operating system error: number = 0x00000020????? HELP???
    Posted by Tony Rain on August 1, 2006 at 12:58 am
    When trying to build a DVD in Encore 2, after I check project, with no errors, and after I click build DVD, it starts to render but then gives this error:
    operating system error: number = 0x00000020 – The process cannot access the file becasue it is being used by another process.
    I have quit evey other program and restarted but nothing works. Anyone know what this means. Anyone know what I can do?
    Thanks.
    Tony Rain replied 20 years, 1 month ago 2 Members · 2 Replies
  • Mylenium
    August 1, 2006 at 10:23 am
    Sounds like you have a DVD-drive that Encore doesn’t like or some system driver/ tool (e.g. Demon tools) is locking your drive. could be a million things. The immedfiate solution would be to create an image file from Encore and burn it using another tool.
    Mylenium
    [Pour Myl
  • Tony Rain
    August 1, 2006 at 6:21 pm
    I actually found this solution in another forum and it works!
    NEW SOLLUTION:
    What i did to solve probelm:
    I belieave this problem is originated from clicking animate buttons and then later un-clicking animate buttons. This corupts the menus that used to have animated buttons. The sollution is as follows.
    1) Save project as a new name.
    2) Save all menus as templates using Menu/save as template.
    3) Delete menus 1 at a time and replace with the templates you saved.
    4) Re-link all buttons.
    Adobe needs to address this issue as it seems to be happening to anyone who clicks animate buttons and then later un-clicks them.
    Thanks for your help!
