Activity Forums VEGAS Pro opening.bak files
  • opening.bak files
    Posted by John Williams on July 8, 2014 at 8:25 pm
    I have Sony Vegas Pro 12. I accidently deleted a project and was able to undelete a name.veg.bak file. I cannot open it. in older post it said put the file in vegas and it will open. Did not work . i got “none of the files dropped on vegas pro could be opened”
    Another suggestion was to drag file on to the vegas icon. This opened vegas but a warning said “an error occurred while loading the project file” and the “file is an unsupported format” and the file did not open
    John Williams replied 12 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    July 8, 2014 at 9:20 pm
    You need to remove the .bak from the file name and then it should open as expected.
    Once you recover it, immediately resave it under a new name.
  • John Williams
    July 8, 2014 at 10:44 pm
    Did not work. Got
  • Mike Kujbida
    July 8, 2014 at 11:43 pm
    Strange. That should’ve worked. Just to confirm you did rename it like myfile.veg.bak to myfile.veg, correct?
  • John Williams
    July 9, 2014 at 8:20 am
    “Strange. That should’ve worked. Just to confirm you did rename it like myfile.veg.bak to myfile.veg, correct?”
    Yes
  • Mike Kujbida
    July 9, 2014 at 10:32 am
    Sorry John but you have me stumped. All I can think of is that the bak file is corrupt 🙁
  • Seb Smith
    July 10, 2014 at 11:19 pm
    I’d recommend making sure you have visible file extensions:
    https://windows.microsoft.com/en-us/windows/show-hide-file-name-extensions
    (Google show file extensions ‘yourOS’
    Before you attempt to rename the file. If you rename without doing this you’ll have ‘filename.veg.veg.bak’ with ‘veg.bak’ being the actual extension.
  • John Williams
    July 11, 2014 at 10:09 am
    “I’d recommend making sure you have visible file extensions:
    Before you attempt to rename the file. If you rename without doing this you’ll have ‘filename.veg.veg.bak’ with ‘veg.bak’ being the actual extension.”
    I already do have visible file extensions
  • John Williams
    July 22, 2014 at 8:34 am
    Please unsub my email from all newsletters. i did not sign up to newsletters, you insist i use my real name here and use it to spam me. do not send me any more newsletter or any communications. i will go to another site with vegas questions.
    I have unsubbed twice so please ensure my email is removed from your spam database
