Activity Forums Apple Final Cut Pro Legacy opening v5 in 4.5
  • opening v5 in 4.5
    Posted by Lisa Virtue on November 14, 2005 at 2:48 pm
    Hi All,
    I have a project done in v5 and need to use it on a different machine that is system 4.5. There did not appear to be any “save as…” an earlier version, so I tried exporting an edl, both as source and as master. When I imported the edl in v4.5 the audio edits are all visible, but the video is just one long clip (The project is built with only jpg images, and the clip is labelled as the first jpg).
    Has anyone managed to successfully work backward in FCP? Any hints you could drop my way?
    Thanks a ton.
    Lisa
    Lisa Virtue replied 20 years, 10 months ago 3 Members · 3 Replies
  • Shane Ross
    November 14, 2005 at 3:29 pm
    Export an XML…version 1. Then open that in FCP 4.5 and reconnect.
  • Bouncing Account needs new email address
    November 14, 2005 at 3:30 pm
    From FCP 5:
    Export > XML…
    Import that into FCP 4.5
  • Lisa Virtue
    November 14, 2005 at 4:42 pm
    Great, thanks. I’ll give that a try.
