Activity › Forums › Apple Final Cut Pro Legacy › Opening scopes cause timeline force render issue
  • Opening scopes cause timeline force render issue
    Posted by Jeff Carson on February 11, 2008 at 4:56 pm
    I captured some ProRes 59.94 422 clips, dropped them into a 59.94 timeline and they play fine without rendering. When I go to “Tools” and open the “scopes”, the red bar (force render) appears in the timeline. The timeline has not changed its format. When I close the “scopes” window, the red bar disappears. Is this just a weird anomaly or is it a bug? It does NOT happen with clips captures as DVCProHD in a DVCProHD timeline as far as I can tell.
    Dual 3Gb Mac Pro Intel 8 Core, 5GB RAM, OS 10.4.11, QT 7.3, FCP2 6.0.2, CS3, AJA ioHD
    Jeff Carson replied 18 years, 7 months ago 3 Members · 4 Replies
  • Chris Borjis
    February 11, 2008 at 5:02 pm
    I was noticing this two weeks ago with DVCPRO-HD and the realtime color corrector with more than one correction.
    It goes orange, but back to normal layout its not there.
    both still play in realtime.
    does it play for you?
  • Jeff Carson
    February 11, 2008 at 5:34 pm
    No, it will not play back without rendering.
  • John Pale
    February 11, 2008 at 9:34 pm
    Turn off realtime scopes (right click on the scope for the context menu) and you should be fine. You will still be able to read the scope when paused.
    Your system is not fast enough for realtime scopes at this resolution.
  • Jeff Carson
    February 11, 2008 at 11:44 pm
    Thank you John. That did it. I forgot about that one.
