Activity Forums Adobe Premiere Pro Opening PremierePro project opens Speedgrade instead
  • Opening PremierePro project opens Speedgrade instead
    Posted by Tom Jackson on November 30, 2013 at 2:20 pm
    Double clicking any saved Premiere Pro project on my Mac Pro now opens Speedgrade instead. I have to first open PPro and then select the project to open. Anyone else experiencing this behavior with the October upgrade in CC 7.1?
    Nicholas Hine replied 11 years, 8 months ago 5 Members · 5 Replies
  • Peter Garaway
    December 2, 2013 at 6:48 am
    Hi Tom,
    I haven’t seen this myself but try doing the following.
    Right-click on the Premiere project file> Get Info> Open With: Choose Adobe Premiere Pro CC.
    Hope that does the trick.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Tom Jackson
    December 2, 2013 at 12:52 pm
    Thanks Peter, I had a private post that suggested the same thing and that fixed the problem. Never had that happen before.
  • Mauricio Ageno
    October 3, 2014 at 8:55 pm
    This is an old post, but it just started happening to me this week. I solved it by right clicking the project file, clicking “Get Info”, then changing the “Open With” drop down menu to Premiere. After that, a button will come up below that saying “Change All”. Click that, and you shouldn’t have a problem with it again.
  • Scott Smith
    October 8, 2014 at 9:14 pm
    When opening my premiere project it opens SpeedGrade as well. I changed OPEN WITH to premiere and it worked. But every time I open that project again, it opens Speedgrade again. It’s automatically defaulting Speedgrade as the Open With program. Please help! incredibly annoying.
  • Nicholas Hine
    January 20, 2015 at 12:39 pm
    Hello i too have that problem with the latest version of CC.
    I can right click and open with PP, next time i log on, same thing it tries to open with SG.
    If i try other, then PP and check Always Open With it says:
    “The item is either locked or damaged, or in a folder you don’t have permission to modify (error code -39).”
