Activity › Forums › Adobe Premiere Pro › opening premiere CS3 project in premiere pro 2.0
  • opening premiere CS3 project in premiere pro 2.0
    Posted by David Knight on March 13, 2008 at 5:44 pm
    Is there any way to open a Premiere CS3 project in Premiere Pro 2.0? I have tried this but it always crashes Premiere Pro 2.0. Is there some special way to save the CS3 project to allow this, or is it just not possible?
    Jon Barrie replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jon Barrie
    March 13, 2008 at 10:07 pm
    You can’t go back. That’s been the thing will so many programs for years now. So your quick answer is no.
    However, there is a workaround which has been used for years going from one NLE to another irrespective of the version or app.
    EDL. You will need to run on a single layer of video and will probably lose a heaps of effects and such, it will pretty much be a cuts and cross fades only timeline. You will need to relink all the footage or recapture.
    AAF. This one I haven’t tested, but in theory should do the same thing. It should keep most of if not all of the edit and effects.
    – Jon 🙂
    How many editors does it take to change a light bulb?
