Activity Forums Media 100 opening old SD PAL Projects
  • opening old SD PAL Projects
    Posted by Paul Friedli on December 3, 2007 at 9:36 am
    Hello,
    Since updating a customers HDe system to 12.0.2, i’m encountering errors when opening old pal sd projects with 768 x 576. the error happens when a title laid over a video clip (a or b). when the title is over a black clip or no clip at all no errors occur. this wasn^t an problem in 12.0.1. any idea when we can expext the next fix to those many bugs in 12.0.2
    Floh Peters replied 18 years, 9 months ago 2 Members · 1 Reply
  • Floh Peters
    December 3, 2007 at 10:20 am
    [Badbiker] ” any idea when we can expext the next fix to those many bugs in 12.0.2″
    What bugs in 12.0.2 would you like to see fixed? The engineers can only fix bugs they know about, so it is good to let them know what problems you have. The problem you described earlier with opening old timelines is new to me, and I am not really sure if there is anything between V12.0.1 and 12.0.2 that would cause this effect. Are you sure that you opened a timeline that worked under 12.0.1, or could it be the case that this problem already existed there? Can you post a timeline that shows your problem with a detailed description somewhere?
