Activity Forums Storage & Archiving Opening Mounted LTFS Tape Fails
  • Opening Mounted LTFS Tape Fails
    Posted by Tom Carlson on July 28, 2018 at 4:57 pm
    Hi All,
    Been a while! I’ve been successfully backing up and restoring LTFS tapes using Tandberg’s LTFS Manager for several years now. However, I have just run into a new problem: I can back up to LTO-5, 6 and 7 successfully. As long as I leave the tape mounted after backing up, I can access all of the files just like a regular drive, although of course taking longer to open up folders. However, if I unmount the tape and then remount it, the first time I double click on the tape, I am taken to a new finder window and the tape disappears off of the desktop (unmounts). The tape can no longer be mounted then, unless I reboot. So, the short explanation is, I can mount the LTFS file system, but can’t access any of the files.
    Has anybody else seen this and do you know of a cause and fix? I’ll put in a support request to Tandberg as well, but thought someone on the forum might have some thoughts.
    Thanks in advance,
    Tom Carlson
    Mac OS X 10.11.6
    LTFS Manager 3.3.0
    Mac Cheesegrater with 2 X 3.46 processors
    96 GB RAM
    Please let me know if there is any more relevant information anyone would like…
    Tom Carlson replied 7 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
