Activity › Forums › Maxon Cinema 4D › opening .MAX files
opening .MAX files
Posted by Yoondo on June 16, 2006 at 7:50 amHello.
How do I open .MAX format in c4d?
Is this possible?Thanks a lot.
Michael Munkittrick replied 20 years, 1 month ago 5 Members · 11 Replies -
Samir Kharchi
June 16, 2006 at 7:55 am.MAX is a parametric file format and cannot be opened by any other application except for MAX (maybe other discreet packages but not c4d).
Simon Carlson-thies
June 16, 2006 at 4:56 pmGet the file converted to .3ds, .fbx, or some other format then you should be fine…
Simon Carlson-Thies
Yoondo
June 17, 2006 at 1:57 amHey, thanks for the reply. What do I use to convert? Perhaps deep exploration? Thanks again.
Simon Carlson-thies
June 17, 2006 at 4:54 amHopefully you can get whoever made the file to save it to a useful format.. but if not check around…
Simon Carlson-Thies
Michael Munkittrick
June 17, 2006 at 5:04 amPolyTrans can change it, but the Max file textures do not translate very well and often get either realigned or omitted completely.
Michael Munkittrick
Gainesville, Florida USA -
Adam Trachtenberg
June 17, 2006 at 5:53 am[Michael Munkittrick] “PolyTrans can change it, but the Max file textures do not translate very well and often get either realigned or omitted completely”
No, Polytrans can only convert a Max file if you have Max installed on your computer.One option is to download the Max demo which is fully functional for 30 days.
Michael Munkittrick
June 21, 2006 at 3:41 amI’ve never owned 3D Studio Max, but I can redily open projects and output them as 3ds files and thereby import them into C4D. Maybe it’s a fluke, but I have had to convert numerous Max files that are sent in to our studio from other studios. Maybe the Max-to-3ds transform is the link?
Michael Munkittrick
Adam Trachtenberg
June 21, 2006 at 6:06 pm[Michael Munkittrick] “I’ve never owned 3D Studio Max, but I can redily open projects and output them as 3ds files and thereby import them into C4D. Maybe it’s a fluke, but I have had to convert numerous Max files that are sent in to our studio from other studios. Maybe the Max-to-3ds transform is the link?”
Hmm, you’re talking about files with the .MAX extension? If so that’s contrary to everything I’ve been told. -
Michael Munkittrick
June 21, 2006 at 8:04 pmOver the last few years, I’ve had to work with models created in a lot of different applications, so flexibility is the key if we’re going to make money. Last year I got no less than 20 full-blown .MAX scenes that I had never had any experience with. I’ve no idea if it supposed to work or not, but it does. I hate to say it, but I’ve been sucessfully changing .max files to .3ds files for quite a while now, and with the exception of the missing or shifted texture and shaders, they all seem to be intact.
As a side note, I just saw a guy 30 minutes ago do a demo with a tool named “Modo”, and it was CRAZY! It opened everything from .dfx files to .3ds files to .cob to .lwo objects without a hick-up. In fact, Modo opened a very, very detailed scene with about 60 animated elements in it more quickly than I’ve seen from any other package…ever. I asked for the tech-guys over at Okino Software to get some information about the PolyTrans package so I’ll update you when I get a response.
Michael Munkittrick
