Activity Forums Adobe Premiere Pro Opening cs4 in cs3
  • Opening cs4 in cs3
    Posted by Laurent Lavigne on May 3, 2009 at 3:45 am
    I am trying to open a cs4 project inside cs3 because a few of my plugins don’t work. Unfortunately the files are not backward compatible.
    prproj files are xml so I am sure a parser exists out there which makes these files compatible, like a maya 8 scene can be opened in maya 7 (albeit a few functions may be lost but an editing scene file is far simpler than 3d object data)
    Thank you
    Deleted User replied 17 years, 4 months ago 4 Members · 3 Replies
  • Vince Becquiot
    May 4, 2009 at 12:19 am
    Indeed, they are not backward compatible (and never have been) which is the case for most Adobe applications, and I don’t believe there is a workaround.
    Even if you were able to make changes in the xml file to dupe Premiere into thinking that it is a CS3 file, I would assume you might run into some issues. We actually have run into issues opening CS3 files into CS4..
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Eddie Lotter
    May 4, 2009 at 1:57 pm
    Export an EDL from CS4 and open that in CS3. That’s about the best you can do.
    Cheers
    Eddie
  • Deleted User
    May 5, 2009 at 7:39 pm
    Hello Laurent,
    You can save as a AAF, then import this into cs3 wqith no probelms. I just did that on a project where it was all edited in Premiere pro cs4 but for stability issues and pl;ugin problems on cs4 decided to go back to cs3. Works fine, I suggest you try that as the EDl created loads of extra clip files and references.
