Activity Forums Maxon Cinema 4D opening .ai files in c4d
  • opening .ai files in c4d
    Posted by Jake Sargeant on February 27, 2006 at 9:38 pm
    This is a question I should have asked a long time ago. I’m hoping there is a solution for this. When i export some type out of Adobe Illustrator and save it as version 8, i’m able to open it up in C4D. But…..everytime i open the ai file into C4D, it opens and places the text to the top right off of the world center axis. I want the ai file, when i open it to be positioned exactly in the middle of the scene. Is there a preference to set for this? How can i get this to work. It’s really annoying having to use the transfer function on a null object in the middle of the scene to get the type to center exactly to the scene.
    thanks!
    jslicer
    Scott Frizzle replied 20 years, 6 months ago 4 Members · 4 Replies
  • Richard Powell
    February 27, 2006 at 11:42 pm
    Yo Jakie, Cinema reads where your 0,0 is in ai. If you position the crosshairs in ai at the center of your art, Cinema will read it there, and your artwork will sit pretty at Cinema’s 0,0,0. In ai just use a temporary reference box with with a center you can snap to, align, and then snap to guides. Crosshairs (you probably know) are up in the top left corner of the ai screen.
    https://mograph.net
  • Jake Sargeant
    February 28, 2006 at 1:19 am
    yo govinda – rich in wisdom -may the c4d gods bless you abundantly for this helpful bit of advice! that worked:)
    jslicer
  • Union
    February 28, 2006 at 3:08 pm
    I also have a .ai question…… When I bring in v.8 .ai files of words, the object consists of paths for each letter instead of a path for the whole word. How can I get that right?
  • Scott Frizzle
    February 28, 2006 at 7:51 pm
    Select all the path objects in Cinema and go to Functions> Connect.
