Activity Forums Adobe After Effects Opening a door in 3D- trouble with edge
  • Opening a door in 3D- trouble with edge
    Posted by Keri Rainock on September 30, 2008 at 9:04 pm
    I’ve got an illustrated door that I open in 3D space. The client wants the door’s edge to move in space as well to give it a feel of depth. I took the edge that was illustrated on the door into a seperate layer and parented it to the main door, but as the door swings the edge moves around wildly.
    I know my description sounds a little confusing, but pretty much I just want a 3D edge to stay hooked to a layer rotating in 3D space.
    Keri Rainock replied 17 years, 11 months ago 2 Members · 2 Replies
  • Amit Zinman
    September 30, 2008 at 10:20 pm
    What did you use to create the door?
    Also, are you using Layer Styles?
  • Keri Rainock
    October 2, 2008 at 4:56 am
    I figured it out, I just wasn’t thinking about where the side was located from all dimensions- thanks!
