Activity Forums Apple Final Cut Pro Legacy Opening 4.1 Project in 5
  • Opening 4.1 Project in 5
    Posted by Bill on August 9, 2005 at 3:21 pm
    i am trying to open a project file saved from a while back on the new system. FCP 5 will not even recognize the old project file. File Error: wrong Type…..any ideas. I can export it out on an old system as an xml…. but there should be an easier way.
    Walter Biscardi replied 21 years, 1 month ago 3 Members · 3 Replies
  • Bill
    August 9, 2005 at 5:15 pm
    okay as much as i hate to admit this… it is a total timmayyy (from south park) tuesday. all i had to do was add the .fcp extension. for some reason all of my old files did’nt have the extension….
  • Bret Williams
    August 9, 2005 at 5:45 pm
    Extension? Final cut project files don’t use extensions. They don’t even have the option to show/hide the extension. I’ve never seen nor used an extension for final cut, but I’m glad you got your project open.
  • Walter Biscardi
    August 9, 2005 at 5:54 pm
    [Bret Williams] “Extension? Final cut project files don’t use extensions. They don’t even have the option to show/hide the extension. I’ve never seen nor used an extension for final cut, but I’m glad you got your project open.”
    actually, yes they do. With FCP 5.0 you’ll see the extension show up as .fcp when you save a file. I’ve not had to add an extension to a 4.0 project, but apparently some folks will have to add it to make sure they open.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
