Activity › Forums › Boris FX Particle Illusion › OpenGL problems
  • OpenGL problems
    Posted by Dennis Svensson on October 8, 2008 at 3:48 pm
    I had PI3 Running perfectly smooth for a couple of weeks ago, when i decided to update my videodrivers for my ATi Radeon x1950 Pro.
    Then after the update, the program shows me the message “OpenGl Hardware Acceleration Is not available, Sofware rendering must be used”
    PI3 now runs like dirt in the gears and It’s impossible to watch any big effects with any resolutions over 100*100 or it will lag like hell.
    I tryed reinstalling, but still the same.
    Intel Dualcore 3,4 GHz
    ATi Radeon x1950pro (AGP)
    2Gb Ram DDR(2?)
    Help?
    Alan Lorence replied 16 years, 4 months ago 3 Members · 6 Replies
  • Alan Lorence
    October 8, 2008 at 8:18 pm
    Are the new drivers “released” or “beta” drivers? If beta, use the latest that are not beta and see if that fixes it.
    Alan.
    http://www.wondertouch.com
  • Dennis Svensson
    October 9, 2008 at 2:49 pm
    My drivers are the latest Released from ATi.
  • Alan Lorence
    October 9, 2008 at 10:31 pm
    Oh, just thought of something else. In pI3 Prefs, OpenGL page, check the “do not request accumulation buffer” option, click OK to close prefs, then close pI3 and launch it again.
    If that doesn’t work… If it were my system, I’d probably go to the previous version of the drivers (next-to-latest) and see if that works, then work my way back one version at a time. Worst-case you end up with the same version you had previously.
    Please post your results!
    Alan.
  • Dennis Svensson
    October 14, 2008 at 1:31 pm
    here are my results.
    I tried your solution, but there weren’t any options saying accumulation buff.
    — I didn’t have any opengl Page so to speak.
    I asked ATi support about the problem and they told me to update the CCC (catalyst control center), so i reinstalled the drivers and the CCC and now it’s working properly again!
    I’m still thank you for the quick response on the support. =)
    And i hope this issue helps some other guys having this problem in the future.
  • Hugo Misagna
    May 15, 2010 at 10:52 pm
    En mi pc el opengl está habilitado.
  • Alan Lorence
    May 16, 2010 at 3:56 pm
    ¿Quiere usted decir con discapacidad? (No habilitado)
    ¿Tiene un problema?
    Alan.
