Activity › Forums › Maxon Cinema 4D › OpenGL issues with ATI Radeon HD 7950 Cinema 4D Blackscreen & Grey Lines
  • OpenGL issues with ATI Radeon HD 7950 Cinema 4D Blackscreen & Grey Lines
    Posted by Deledi Bingham on October 15, 2012 at 12:50 am
    I downloaded the r14 cinema 4d trial because I am interested in purchasing some 3D software.
    First off, I had a black screen and upon researching the issue it appears to be a problem with openGL so I turned it off and I could view the grid but then I would have random grey vertical lines appear within the window.
    I am curious if anyone has a 7000 series radeon card and has been able to make Cinema 4d work for them with openGL turned on. Perhaps using an older GPU driver?
    I really like what I see so far but I want to know if my GPU is going to be a bust for this software which means I will need a new GPU as well.
    I purchased the 7950 in the first place to take advantage of sony vegas render boost and so ideally I would be able to keep the ati card while getting cinema 4d and my other opengl programs to work with the card as well.
    Hakan Arko replied 13 years, 6 months ago 5 Members · 5 Replies
  • Sam Wells
    October 16, 2012 at 12:03 am
    I had the same issues with my Radeon HD and R13, roll back to Catalyst 11.2 should work fine.
  • Deledi Bingham
    October 17, 2012 at 4:41 am
    ok thanks I will try that..
    Out of curiosity what graphics card do you have and have you tried the r14 demo? I assume you use r13 right now and it works for you correct?
    I wonder if the 11.2 drivers will work with a 7950 on r14.
  • Sam Wells
    October 17, 2012 at 5:40 am
    Good luck. Yeah, I use an older hd5770 and experienced the problem you describe with r13, from what I can tell from hunting around recently the problem lies in the newer catalyst open gl drivers, and the most stable driver was 11.2. Post back with the result.
    Sam
  • Romanshark Deejay
    February 13, 2013 at 10:14 am
    I found a quick solution that may fix the issues with ATI Catalyst 12.X and up with OpenGL in Cinema4D (it worked for me in R14 with ATI Mobility HD 7470M & Catalyst 13.1):
    1. Just go to C:Windows
    2. Make a copy of atiogl.xml file
    3. Open atiogl.xml and edit with notepad or other (like DreamWeaver or WordPad).
    4. Scroll down until you find the section named “Cinebench”
    5. Delete all the section of Cinebench (it should be something like this, delete all these):
    <!-- Cinebench -->
    6. Now restart Cinema4D and you can activate OpenGL again in Preferences and make it work.
    Extracted from: youtube.com/watch?v=G2LcGhj-KgA
  • Hakan Arko
    February 27, 2013 at 8:37 pm
    ı have Cinema4D R14 bugreport problem (OpenGL)
    ı want to try new version R14 but it’s dont open on my laptop and desktoppc.
    ı search on internet this problem (İt is OpenGL problem.) and found much solution.
    but dont work
    pls help me
    my laptop:
    İntel(R) Core(TM)2 Duo
    4GB DDram
    NVIDIA GeForce gt 240m
