Activity › Forums › Apple OS X › OpenGL issue
  • OpenGL issue
    Posted by John Filipkowski on July 21, 2005 at 5:16 am
    First off- 800mhz G4 Powerbook
    1 GB Ram
    OSX 10.3.9
    I recently updated from 10.3.5 to 3.9. When doing this from the update menu, the main OS update stalled at 97% complete for about an hour. I quit the updater and tried once again. It worked, but the next time I tried to start the computer, it got to the grey apple with the loading circle, followed by a blue screen which then slowly turned grey. I could not do anything after that. Now, the only way to get into my computer is if I hold down the option key when booting up. Also, when starting Adobe After Effects it puts up an error: couldn’t load plug-in “openGL3D” (Problem with fragment “ <>“)-code fragment library not found (-2804) Would this have anything to do with my boot up problem. If someone could help, it would be much appreciated.
    John
    John Filipkowski replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
