Activity › Forums › Adobe After Effects › OpenGl crashes
OpenGl crashes
Posted by Dotan Stern on January 28, 2009 at 11:01 amHi i just bought Gforoce 8500GT and i get lots of OpenGl crashes using AE CS3
any idea how to solve this issue?
also i have a chance to change the video card to something else any suggestion to what to choose?
i have AMD 3800X2 with 4GB
thank youThomas Leong replied 17 years, 7 months ago 4 Members · 6 Replies -
Grant Swanson
January 28, 2009 at 1:21 pmOpenGL has very few good uses in After Effects. With the exception of working in 3D (and even this isn’t always smooth), you’d be better just turning it off altogether.
Grant Swanson
Visual Effects Supervisor
Video Apex – Minneapolis, MN
videoapex.net -
Grant Swanson
January 28, 2009 at 1:26 pmI will also add that the nVidia Quadro line of cards work much more smoothly with OpenGL than the GeForce line…so if you can switch like you say you can, it may or may not be worth a shot.
Again though, OpenGL is really only meant for 3D in After Effects, and it doesn’t always do a great job on that.
Grant Swanson
videoapex.net -
Dotan Stern
January 28, 2009 at 1:40 pmThanx for the reply grant
well after playing a bit with 3D scenes it runs much better with the Opengl on then the adaptive resulution
and on other scenes its the other way arround
Quadro video cards are more expensive and as you say Opengl doesnt work that good so there is no need to pay more then what i have now
but i can get a different card in the same value of this one
i red here about radeon X1950 is it better then the one i have now?
or should ill stay with what i have
thanx -
Dotan Stern
January 29, 2009 at 8:44 amHey guys so what do you think should i change my video card to the radeon X1950?
thanx -
Daniel Cabral
January 29, 2009 at 11:02 amI have a dream…
where Adobe finally makes AE uses CUDA/OpenCL to REALLY accelerate our works…
But i’m still dreaming…
Thomas Leong
January 29, 2009 at 4:06 pm“…should i change my video card to the radeon X1950?”
According to Tomshardware.com’s latest Graphics Card Hierarchy chart, the Radeon X1950 is a few classes above the GeForce 8500GT. So if you can change the latter for the X1950 without additional outlay, I’d say go for it.
BTW, OpenGL itself has various versions and within every version there are a myriad of sub-sets which an application may implement, or choose not to. The graphics card a user chooses would have to, as a minimum, support the same sub-sets of OpenGL that the application has chosen to implement. Else there will be incompatibilities probably resulting in crashes. I do not see any details of the OpenGL sub-sets required for any particular version of AE at Adobe’s site, so I’m afraid it is a buy-and-pray situation unless someone can provide the OpenGl sub-sets required for your version of AE such that you can check them against your gfx card and its driver.
Sub-sets aside, you can nevertheless check whether your gfx card and its driver are using OpenGL 2.0 which would be a must for more recent versions of AE. To check your version of OpenGL (Windows or Mac) use this Tool at –
https://www.realtech-vr.com/glview/download.htmlhope that helps,
Thomas Leong
