openexr multi pass
I am in the process of rendering a scene using openexr for the first time – I was under the impression I would get single .exr files which I would then unpack within after effects etc
I am half way through my render and I noticed that I have separate files for all the paths I selected – am I missing something?
I deselected the top portion in the save column and used the multi pass section at the bottom
having said that – what is your favorite multi-pass technique and why?
thanks for your time
p.s. I used this cheat sheet for my settings https://www.flipswitchingmonkey.com/2015/03/cinema-4d-and-after-effects-openexr-multi-layer-workflow/
