Activity Forums Maxon Cinema 4D Open up sphere and animate out
  • Open up sphere and animate out
    Posted by Sabine Waring on May 13, 2011 at 11:50 am
    Hi everyone,
    I’m looking for some pointers on how to animate a sphere open.
    I have two hemispheres that have bevelled edges, giving the impression of a sphere split in half. I have one outer sphere around them that I would like to animate to reveal the split underneath (making it look like the outer sphere is actually breaking in half).
    I need the outer sphere to sort of open up and rotate out, but I have absolutely no idea how to go about this. My Cinema knowledge is fairly limited, so I’d really appreciate some help.
    Tim Shetz replied 15 years, 3 months ago 3 Members · 5 Replies
  • Adam Trachtenberg
    May 13, 2011 at 1:32 pm
    I’m not sure if this is exactly what you’re going for, but I did a tutorial a while back that might give you some ideas: https://www.3danvil.com/tutorials/folding%20sphere/Folding%20Sphere.html
  • Sabine Waring
    May 13, 2011 at 4:13 pm
    Thanks for your comment, I tried splitting the circle and rebuilding it using an array, but it is not giving me the result I want.
    I made a little graphic to demonstrate what I am after:
    I tried animating the amount of sides in the array to open up the circle, but this does not open up one big hole but holes between all the sides =(
  • Tim Shetz
    May 13, 2011 at 6:18 pm
    Is this what you are trying to accomplish?
    I used an arc in a lathe nurb, put the lathe nurb in a symmetry object and animated the angle of the lathe nurb.
    __________
    Tim Shetz
    c4dtraining.com
  • Sabine Waring
    May 13, 2011 at 10:20 pm
    Thank you so much, that is exactly what I was looking for!!
  • Tim Shetz
    May 14, 2011 at 12:04 am
    Awesome…so glad I could help.
    __________
    Tim Shetz
    c4dtraining.com
