Activity Forums Maxon Cinema 4D Open up in Illustrator
  • Open up in Illustrator
    Posted by Dave Montague on October 22, 2008 at 3:05 am
    I used to be able to open line drawing in illustrator and work with them in C4d. I have CS3 and I am saving the files as AI 3.0 like I used to. The problem is when I extrude I loose any holes or any other internal shapes within the line drawing.
    Any help would be appreciated.
    Thank you!
    Kelly Johnson replied 17 years, 10 months ago 2 Members · 1 Reply
  • Kelly Johnson
    October 22, 2008 at 3:20 am
    I guess you’ve checked to make sure Hierarchicals is checked in the attributes manager on the Extrude?
    I have CS3 and I always save as an Illustrator 8.0 file or something an Illus 8 eps.
