Activity › Forums › Compression Techniques › Open Source Blu-ray Encoding
  • Open Source Blu-ray Encoding
    Posted by Clint Milner on October 13, 2010 at 3:22 pm
    I was wondering if there were any new developments with either AVC, VC-1, or MPEG2 encoding.
    This link:
    https://x264dev.multimedia.cx/archives/328?info=EXLINK
    looks interesting, but I’m looking for just encoding and everything I can see here seems to point to an all-in-1 authoring solution.
    I currently use the HC Encoder for SD footage and IMHO it out performs my Adobe Media Encoder, Procoder 3 and in some instances our Cinevision encoder. I’ve read that it can handle video with larger dimentions than the SD spec, but I’m assuming it’s MPEG-2. Also, I’m not sure if you can you jack up the bitrate over 9 in HC?
    Any insight would be really helpful.
    Many thanks,
    Clint
    Adobe CS4 Master Suite
    Vista Ultimate 64 SP1
    Intel Core i7 920 @ 3.60GHz
    12 GB DDR3 RAM
    NVidia Quadro FX 3700
    Matrox RT.X2 LE Capture Card
    4 TB RAID 5
    Clint Milner replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
