Activity Forums Apple Final Cut Pro Legacy open mxf files in FCP 6
  • open mxf files in FCP 6
    Posted by Maayan Cohen on December 30, 2008 at 10:08 pm
    I am trying to open mxf files in Final Cut Pro 6. The files have mov extension as well as mxf extension:
    filename.mov.A49496383.mxf and they are exported from AVID.
    With these files I also have msmFMID.pmr file and msm.mmob.mdb file. Are these apart of the work project file?
    Is there a way to convert them to a quick time file so they would play on FCP? if i need to use another program to convert them can you recommend one?
    Many thanks,
    Maayan
    Dan Marlow replied 17 years, 8 months ago 4 Members · 4 Replies
  • Rafael Amador
    December 31, 2008 at 12:21 pm
    Hi Maayan,
    Type “mfx” in the search window and I bet that you will find the answer.
    Happy New Year,
    Rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    January 2, 2009 at 11:37 pm
    You’ll want this:
    https://mxf4mac.com/mxf4qtimport
  • Maayan Cohen
    January 2, 2009 at 11:50 pm
    Thank you!
    I managed to open the files with Caliberated software, but I am now stuck with the AVID project files that I need to open ( msmFMID.pmr and msm.mmob.mdb ). Is there anyway that I can open these files without purchasing Automatic Duck https://www.automaticduck.com/products/?
    Maayan
  • Dan Marlow
    January 3, 2009 at 9:54 am
    If you have access to an Avid to open the project you could export an EDL and an XML from the Avid and try linking the the imported EDL or XML in FCP to the MXF media. Dont know if this works, but worth a try.
