Activity Forums VEGAS Pro “Open in audio editor”
  • “Open in audio editor”
    Posted by Don Hutcheson on November 30, 2009 at 11:52 pm
    I’m trying to raise volume levels and work on some echo, and when I select “Open in audio editor’, the timeline in Cool Edit Pro doesn’t show a normal audio visualization. It is totally green (obviously overdriven levels) and all I hear is metallic noise. I thought it might be importing the video along with audio, but when I “cut” the video track, the same thing happened. What am I doing incorrectly?
    I’m using Vegas 7 in Windows XP/4G memory, and I know that both programs work in XP (but not together yet).
    Thank you,
    Don
    Hutch
    Terry Esslinger replied 16 years, 9 months ago 3 Members · 4 Replies
  • Danny Hays
    December 4, 2009 at 2:18 am
    Does the waveform look normal in Vegas? (Not square waved)? Vegas was just an audio editor for the first two versions and can do alot with editing audio, If all else fails, try rendering the file as a Microsoft Wave, then open it in Cool Edit. Danny
  • Terry Esslinger
    December 8, 2009 at 5:17 pm
    Have you tried ‘open a copy’ in sound editor rather thatn ‘open file’; in sound editor?
  • Don Hutcheson
    December 8, 2009 at 11:04 pm
    Yes. I was able to do it. But that’s as far as I went. I wasn’t sure if (a) the metadata is attached to the “copy”, so I can save the copy as a file and re-import the improved file to the timeline in a way that it will snap (sync) to the video file and (b) does Vegas have a procedure for removing echo (or, at least, reducing it)?
    I’ve read about making a copy, putting it on another track in reverse phase and playing with the settings.
    Thanks Terry
    Hutch
  • Terry Esslinger
    December 9, 2009 at 4:50 am
    It will be saved and placed in the timeline as a ‘take’.
