Activity Forums Boris FX Open GL supported or not..help?
  • Open GL supported or not..help?
    Posted by Sean Brennan on August 13, 2009 at 10:38 am
    Hi, I have a Nvidia QuadroFX 500/FX600/AGP/SSE2 OpenGL version 2.1.0. In the supported cards list it says Quadro FX – all so I assumed it was supported however I get “your systems video card driver is not supported by Boris RED – disabling OpenGL.
    I have updated the drivers via Windows 7 to the latest, is there something I’m missing to get this to work?
    thank you
    Sean
    Peter Mcauley replied 17 years ago 2 Members · 3 Replies
  • Peter Mcauley
    August 13, 2009 at 1:28 pm
    Hi Sean,
    I’m not sure what to tell you other than this is most likely a driver / OS related issue. I believe we suggest using the driver 182.65 for our OpenGL rendering – are you using that driver on your system? Also, you state that you are using MS Windows 7 … RED 4 has not been qualified to run under that (yet to be released) version of Windows. Are you able to run RED with OGL disabled?
    Cheers,
    Peter.
  • Sean Brennan
    August 13, 2009 at 7:48 pm
    Yes Red seems to be running under Windows 7 with OGL disabled. I am still testing.
    where do I find the driver 182.65?
    Not sure what one I have ..there’s so many numbers and versions it’s confusing and not very clear. One sales person told me that Quadro FX 500 isn’t supported with Boris as there’s not a driver! thanks
  • Peter Mcauley
    August 14, 2009 at 12:39 pm
    If you go to the Nviidia site and perform a manual driver search (there’s a box for this) you will find the driver. Here’s a link to the search that I ran:
    https://www.nvidia.com/object/nv_search_us.html?cx=009029091075083507105%3A9leknaf7r_8&cof=FORID%3A11%3BNB%3A1&ie=UTF-8&hl=en&gl=us&q=182.65
    While I was there I looked into their driver support for Windows 7 and the Quadro FX 500 card that you have – it’s not listed as a supported card by Nvidia, which may account for the problems that you are seeing.
    Anyway, please give the 182.65 driver a shot and let us know how that works for you.
    Cheers,
    Peter.
