Activity Forums Maxon Cinema 4D Open GL question
  • Open GL question
    Posted by Jack Cook on December 16, 2010 at 5:00 pm
    I’m using R12 on Mac OS 10.6.5.
    I want to make a huge environment consisting of a seabottom and a water surface, to show a scientific mooring in deep water. I made a Landscape object, and sized it to be 1000m square. But the whole object doesn’t show up in the perspective view – the front edge appears, and only a part of it shows up. It looks like it disappears behind a curtain. If I zoom in with the camera, more of it appears, and when I zoom out it gradually disappears again. It’s like there’s a barrier beyond which you cannot see.
    So I looked around in the preferences and found the Open GL tab. I disabled Open GL and voila! the whole scene is now visible, but the quality is low. I can probably live with this, but can anyone explain to me why this happens when Open GL is enbabled? Is there a way around this?
    Here’s a screenshot.
    thanks,
    Jack
    Jack Cook replied 15 years, 9 months ago 2 Members · 2 Replies
  • Les Nemeth
    December 16, 2010 at 7:08 pm
    Could it be that your view clipping is set too small? Adjust Edit > Project Settings… > View Clipping dropdown
  • Jack Cook
    December 16, 2010 at 8:47 pm
    That was it! Thank you! I didn’t even know that setting was there.
    Jack
