Activity Forums Adobe After Effects Open GL Problems with my VAIO and AE
  • Open GL Problems with my VAIO and AE
    Posted by Clifford L. frazier on November 22, 2005 at 5:17 am
    Greetings, I just purchased a new laptop Sony Vaio VGN-S480P 2 GIG ram 100 GIG HD. I installed my AE 6.5. When I tried to do a test project, I got the following error message: After Effects Error: OpenGL:Problem creating the texture object (5044::0) Now, I do remember having a similar problem with my Vaio VGN-S170P computer. I had to change some accelerator setting or something. But I cannot remember what I did. Also, I’m not exactly sure that this is the same problem. If anyone nows what the problem is please advise as my project is being held hostage to this problem. Thanks
    The TechnoRev.
    Josh Miller replied 20 years, 9 months ago 2 Members · 1 Reply
  • Josh Miller
    November 22, 2005 at 6:37 am
    Hey,
    1. Make sure your in a 32-bit environment on your color adapter
    2. If you are in 32bit go to Edit>Preference>Previews>OpenGL Info… and then try changing the Texture Memory
    Hopefully one of those steps will work,
    Josh M
