Activity › Forums › Adobe After Effects › Open GL error (fragment shader at -1)
  • Open GL error (fragment shader at -1)
    Posted by Michal Šteflovič on December 13, 2010 at 9:31 am
    Hi, I looked for this problem on the forums, and basically anything I could not find a solution … and never really do not know where to go … makes it as in AE CS3, CS4 and Premiere CS3 too even if you select a plugin Magic Bullet Looks so it will write this An OpenGL error occurred while attempting to load the frame (fragment shader at -1)and even this an OpenGl error occurred while attempting to load the frame (glTexSubImage2D: 1282) I have a reinstallation WINxp32bit and before that it did not work … I’ll be glad for any advice, thanks
    Jim Cliff replied 15 years, 9 months ago 3 Members · 2 Replies
  • Tim Vaughan
    December 13, 2010 at 4:39 pm
    Heck, don’t use openGL at all. Save you a headache overall.
    Tim
  • Jim Cliff
    December 23, 2010 at 3:25 am
    I have this same problem. It comes up automatically on going into Looks. How do I avoid using OpenGL?
