Activity Forums Adobe After Effects Open GL crash question
  • Open GL crash question
    Posted by Mark Dalzell on October 24, 2008 at 9:15 pm
    I just got an error message regarding OpenGL. I was wondering if I need to make any adjustments in AE/CS3. I’ve never edited HDV with AE so please excuse my ignorance.
    Any help would be greatly appreciated.
    Regards.
    Mark Dalzell
    Here’s some info that maybe useful:
    Under Preference/Previews:
    Fast previews / Adaptive resolution limit = 1/4
    Enable OpenGL is checked
    Accelerate effect using OpenGL (when possible) selected.
    OpenGL Info:
    Vender: Nvidia
    Renderer: GeForece 9600GT/PCI/SSE2
    V.2.1.2
    Texture memory: 200mb
    More accurate capabilities: Everything is supported
    Capabilities: Everything is supported.
    The project settings:
    Preset: HDV 1080 29.97 / 1440×1080
    Lock aspect ratio checked / 4:3
    Pixel aspect ratio:
    HDV 1080/DVCPRO HD 720 (1.33)
    Frame aspect ratio: 16:9
    Frame rate: 29.97 pr. second.
    PC Specs:
    VisionDAW 4U 8-Core Xeon Workstation
    2 Intel QUAD-Core Xeon 5365-3.0GHz, 8MB, 1333MHz Processors
    16GB 667MHz Fully Buffered Server Memory Modules (2x2GB)
    Microsoft® Windows® XP Professional x64 Edition
    WDC 250GB, Ultra ATA100, 7200 rpm, 8MG Buffer Main OS HD
    MOTU 24 I/O (main) / MOTU 2408mk3 (slave)
    2 WDC 750GB, SATA II, 7200 rpm, 16MG Buffer HD (Samples)
    Plexor PX-800A 18X Dbl. Layer DVD+/-RW Optical Drive
    Front Panel USB Acess
    Integrated FireWire (1394a) interface
    Thermaltake Toughpower 850W Power Supply
    Dual ESATA Bracket
    2 WWDC 750GB, SATA II, 7200 RPM, 16MB Buffer HD (Raid 0)
    3xUAD1 Universal Audio Cards
    EVGA NVIDIA GeForce 9600GT, 512MB,
    PCI-Express, DUAL-DVI Video Card
    Dual 25.5″ Samsung 2693HM LCD HD Monitors
    Gyorfi Szilard replied 17 years, 10 months ago 3 Members · 5 Replies
  • Mark Dalzell
    October 24, 2008 at 9:39 pm
    Dave,
    Thanks for your timely reply. I will disable all OpenGL in AE as you suggested.
    For the second part, what codec(s) do you recommend and where can I get them?
    Again, my thanks for your help.
    Best.
    Mark
  • Mark Dalzell
    October 24, 2008 at 9:55 pm
    Dave,
    So are you saying I need to get a Quicktime animation codec for Windows? Or a Lossless AVI?
    I’m not quite sure what codec my PC needs to convert the files so they would work in AE.
    Thanks.
    Mark
  • Kevin Camp
    October 24, 2008 at 10:12 pm
    if you can’t go lossless or uncompressed, and if you have quicktime installed on you system, quicktime photojpeg is a good free option. i would think that a quality of 75 or so would have little loss for hdv footage…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Mark Dalzell
    October 25, 2008 at 3:55 am
    Dave,
    I own QT Pro.
    I’ll check with some PC AE users to see about codecs.
    Thanks.
    Mark
  • Gyorfi Szilard
    October 31, 2008 at 1:35 pm
    Hi
    I have a suggestion for a good, free, lossless codec that makes your rendered files much smaller than the animation codec.
    I have learned this from one of the tutorials of Aharon Rabinowitz.
    It is called Techsmith codec. If you download Camtasia studio5 , the trial version , from http://www.camtasia.com and install Camtasia to your PC the codec ges installed in all you editing applications.
    Now open AE, and at the render settings select, quicktime, than at the quicktime settings select the techsmith codec.
    I render my videos using this codec .
    Hope it helps you too.
    P.S I have the ame problem with my open GL , I work with it off.
    Gyorfi
    http://www.bluefx.net
