Activity › Forums › Apple Final Cut Pro Legacy › Open Format Timeline — Not Prompting me to Change Setting
  • Open Format Timeline — Not Prompting me to Change Setting
    Posted by David Jolosky on December 23, 2008 at 5:40 pm
    Nothing new in being able to drop a clip onto a timeline and be prompted “do you want to match clip to sequence or match sequence to clip”, but this prompt has stopped popping up when I drop a clip down to a sequence timeline.
    Did I hit a key command accidentally? Tried trashing prefs, nothing.
    Thoughts??
    Thanks!!
    Jeremy Garchow replied 17 years, 9 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    December 23, 2008 at 5:57 pm
    What format is the footage you are dropping in?
    There’s a prefrence for this in the User Prefs:
  • David Jolosky
    December 23, 2008 at 6:06 pm
    Jeremy, thanks for your quick response and insight. I double checked my workflow with this particular project and the piece of footage provided by the client was (this particular piece) was not a standard editing codec or size, it was some crazy 630 x 500 size with the Animation Codec so no wonder FCP didn’t prompt me to make such a timeline.
    I tested against some normal codecs (dvcprohd 720, dvntsc 480, etc.) and all is working as expected.
    I shoulda checked that “last minute” addition that was provided, but assumed it was a normal size piece of footage.
    Once again, thanks for your response, it got me thinking in the right direction.
    dj
    david jolosky, visual communications || design || construct || interact
  • Jeremy Garchow
    December 23, 2008 at 6:10 pm
    No worries!
    Jeremy
  • Joel K.
    December 23, 2008 at 8:08 pm
    it prompts you only on the first clip you add to the sequence. after that, footage with other codecs, image sizes, etc are matched to that sequence.
  • Jeremy Garchow
    December 23, 2008 at 8:14 pm
    Yes, if it’s a standard frame size, frame rate and editable (i.e. rt extreme enabled) codec. If they are non video spec codecs and frame sizes/rates, FCP won’t change the settings but it will rather add the clip to your timeline to whatever the timeline is set to at the time.
    Jeremy
