Activity › Forums › Apple Final Cut Pro Legacy › Open Format – Closed for me
  • Open Format – Closed for me
    Posted by David Kuhnen on July 10, 2007 at 10:19 pm
    Just started testing new setup. Clean install of 10.4.9 and FCS2 on new MacPro 2.66 w/4GB RAM,, AJA LHe w/4.0 drivers.
    Captured in DV, DVCPro50, MJPEG-A, Photo-JPEG and ProRes422.
    All at 525i, 29.97, some obviously at 720×480 others at 720×486. I then created 5 sequences based on the same settings as capture. I dropped all clips into each sequence, made sure to remove all attributes (Motion & Filters) in case FCP tried to correct for field shift or size difference.
    DV codecs play nice with ProRes, but forget about trying to mix either of these with MJPEG-A or P-JPEG. It’s not the 480 vs. 486 since DV is 480 and ProRes is 486. It’s just not as “Open Format” as I would like.
    I deal with a large archive library that I was hoping to capture in P-JPEG because if the acceptable quality at very small file sizes. My upgrade to FCP6 was to enable mixing archives with other (native DV) formats in the same timeline.
    Am I missing something?
    David Kuhnen replied 19 years, 2 months ago 3 Members · 3 Replies
  • John Pale
    July 11, 2007 at 6:00 am
    They have to be FCP RTextreme supported editing formats.
    MJPEG and PJPEG are not supported (basically if you see an Easy Setup for a format, then its supported)
  • James Reid
    July 11, 2007 at 8:00 am
    One additional caveat.
    The Open Format timeline does not deal with 720×486
    content dropped into a 720×480 properly.
    Instead of cutting off 2 lines at the top and 4 lines
    at the bottom of a frame, it resizes the frame…wrong.
  • David Kuhnen
    July 12, 2007 at 1:40 pm
    A big thank you to John & JR.
    John’s information directed me to the right area of the manual for further information.
    Indeed Photo-JPEG is used as an RT Extreme codec but after some trial & error I determined it’s only “RT Extreme” compatible when set to 320×240 which looks terrible.
    So if I want to utilize the Open Format capabilities of FCP6, I’ll use DV for library archives, ProRes (NTSC) for most On-Line and Photo-JPEG (at 320×240) for long program off-lines.
