Activity › Forums › Apple Final Cut Pro Legacy › Open final cut pro 7 project in final cut pro 6
Posted by Ben Northenor on January 24, 2010 at 3:19 amI just got a harddrive from a client to cut a movie. They have all the footage on the heard drive, but organized it in a Project I have FCP6, but the projects were saved on FCP7 and won’t let me open them. It says, “This project is unreadable or may be too new for this version of Final Cut” Thank you in advance.
Cindy Parisotto replied 14 years, 11 months ago 5 Members · 8 Replies -
Arnie Schlissel
January 24, 2010 at 3:48 amYour client can send you an XML of their project. They should send it to you in XML version 4, version 5 will not work with FCP 6.x.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Ben Northenor
January 24, 2010 at 4:18 amI think I’ll just take the hard drive to my buddies house and open it on his final cut and then just make a Quicktime and import it into my older versions project. That will work, right?
Gary Askham
January 24, 2010 at 3:43 pmThis is a common problem and is covered a lot on Creative Cow if you search.
As Arnie said you need to export an XML of the sequence from Final Cut Pro 7. There are specific types of xml which work when going to and from different versions of FCP. All searchable on Creative Cow or just Google.
(it just took me 30 seconds to find this –
Use XML version 1 for going back to Final Cut Pro 4.1
Use XML version 2 for going back to Final Cut Pro 5.0
Use XML version 3 for going back to Final Cut Pro 5.1.2
Use XML version 4 for going back to Final Cut Pro 6
Use XML version 5 for moving between Final Cut Pro 7 systems)————————
FCP and Avid Technical Support
Air Post Production
Shoreditch – London -
Cindy Parisotto
October 31, 2011 at 7:49 pmthanks for the info–
one more question.when using XML to import the sequence, will that make the whole project work? do I need to start a new project and import the new sequence?
