Activity › Forums › VEGAS Pro › Open file, massive delay on playback… loading audio maybe?
  • Open file, massive delay on playback… loading audio maybe?
    Posted by Peter Abbott on May 2, 2009 at 1:28 am
    Whenever I open a past project (typically they contain about 60 one minute clips), there are extremely long delays when I try to play back a clip. Is there an option to speed the loading process up? Is it the audio that is loading and slowing everything up? I feel like there must be an option under preferences, but I can find anything that is relevant.
    Thanks.
    Peter Abbott replied 17 years, 5 months ago 2 Members · 2 Replies
  • D. Eric franks
    May 3, 2009 at 12:01 pm
    It might be the audio peaks loading (as Vegas calculates and draws the visual waveform peak files), but it’s certainly easy to check: During the long load, in the lower left part of the interface, you should see a Cancel button and a progress bar moving from 0% to 100%, with the notation “Building peaks for…” and the file name. You can hit Cancel (or press the Esc key) to stop this on a case-by-case basis (it won’t effect anything, you just won’t get to see the waveform and clips will have “(Peaks not available)” on them instead).
    There are some Preferences you can toggle that might help. Options > Preferences > General tab > Build peaks for visible events only, for example. If your 60 minute clip is on the timeline, then this won’t matter. You can also set Vegas to use half-resolution peak files with Options > Preferences > General tab > Build 8-bit peak files.
    However, once the peaks are built, they won’t need to be redrawn from scratch every time and loads should be relatively fast, so I’m thinking this isn’t your problem.
    ______________
    Television is the first truly democratic culture – the first culture available to everybody and
    entirely governed by what the people want. The most terrifying thing is what people do want.
    — Clive Barnes —
    https://videopia.org
  • Peter Abbott
    May 4, 2009 at 1:41 am
    Thanks for the response.
    I’m aware of the [process bar on the bottom left, but as you know that only shows when I’m first importing the clip. I’ve also tried checking off the 8-bit option, but that didn’t make any difference. And not sure if this matters, but it’s not a 60 minute clip, it’s 60 one-minute clips.
