Activity Forums Adobe After Effects open exr in AE, choosing 32 bit or 16 bit float
  • open exr in AE, choosing 32 bit or 16 bit float
    Posted by Ali Quintana on April 13, 2015 at 12:49 am
    Is there a big disadvantage choosing 16 bit float instead of 32 but float for exr.
    We need to render a 3d max animation at 1080 p in open exr with render elements.
    We need to decide between 32 or 16 bit float. Thing is we are going to use a render farm and the transferring of the files may take time depending on the file size.
    Ali Quintana replied 11 years, 4 months ago 2 Members · 4 Replies
  • Walter Soyka
    April 13, 2015 at 2:35 pm
    Half-float (16b) is smaller, but less precise. Depending on what you are doing, the precision difference may be imperceptible and not worth the added weight during compositing.
    I’d suggest rendering a few frames as a test to help you figure out which is more important to you.
    In general: for visual passes (color, lighting, etc.), half-float is fine. For data passes (motion vectors, world position, etc.), full-float is significantly better.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Ali Quintana
    April 14, 2015 at 6:47 am
    Thank you for the help.
    I am exporting some architectural animations for editing in After effects.
    will do some render elements such as reflection and refraction light, and couple more.
    Render is Vray and we have a day and a night scene with lots of lights.
    I love the linear editing and float especially you can bring down peaked highlights with simple exposure effect.
    Would 16 bit be more then good for this… I am using render farm and need to transfer the files back to my computer of course.
  • Walter Soyka
    April 14, 2015 at 1:04 pm
    [Ali Quintana] “Would 16 bit be more then good for this… I am using render farm and need to transfer the files back to my computer of course.”
    My rule of thumb is full-float for data passes and that half-float is ok for visual passes, but don’t trust some random guy on the internet — do your own quick test to confirm for yourself that you’ll be happy with the result.
    Walter Soyka
  • Ali Quintana
    April 15, 2015 at 12:48 am
    Thanks, I tried it, I am happy with the 16 bit float result, so far… now I have to pay a renderfarm a lot of money to render a heavy 5 min animation.
    I just hope I made the right decision because the real thing will be found out when deep into the render….
    But your rule is not just a random internet guy rule, I have seen on the net many other pros giving the same advice. 16 bit float for normal renders and for data passes 32 bit.
