Activity › Forums › Adobe After Effects › opacity to multiple layers
Posted by Run Rodriguez on October 5, 2010 at 8:07 pmI understand how to use parent layers, adjustment layers and masks, but I can’t figure out how to make one layer change the opacity of multiple layers. Any tips?
Sabah Shahdi replied 11 years, 2 months ago 3 Members · 2 Replies -
Andy George
October 5, 2010 at 8:19 pmThis would be a good job for expressions.
You can use the quickwhip to link the opacity of one layer to another for an expression that would look something like this:
thisComp.layer(“Red Solid 2”).transform.opacityThen copy this expression (edit-copy expression only) and paste it onto as many additional layers as you like.
An easier to control method might be to add the Slider effect to a layer and then quickwhip your opacity to the slider for an expression that would look more like this:
thisComp.layer(“Red Solid 3”).effect(“Slider Control”)(“Slider”)
These websites does a good job of explaining how expressions work
https://www.jjgifford.com/expressions/basics/index.html (more basic)
https://www.motionscript.com/-Andy George
Senior Editor
http://www.chiselindustries.com -
Sabah Shahdi
July 22, 2015 at 11:56 amHi dear.
I imported an illustrator world map to after effect which is in layers (each country has a layer).
I’m trying to make a world map that will be scanned from left to right.
a simple solid layer will make scanning process.the question is that how link opacity of each layer to position of that solid?
when that solid crosses over a layer, opacity of that layer change to maximum value and in other cases opacity change to minimum value.I think it is possible to link the opacity of a layer to position of another layer, but how?
