Activity Forums Adobe After Effects Expressions opacity that holds on a random “hit”…
  • opacity that holds on a random “hit”…
    Posted by Erin Shelby on November 12, 2007 at 3:37 am
    Hi all,
    I have a solid that has the following expression on opacity:
    seedRandom(true);
    x = random(8);
    if (x=1) 100 else 0;
    so, as you all know, it’s basically a 1 in 8 chance if the frame is full opacity. Right? But the problem is I want it to “hold” for 10 frames if the random number “hits” – then after the hold to go back to the ‘randoming’ process. Is this possible within after effects? I know I could possibly do some checking function – but I’m not sure how to make it elegant…
    -E
    Erin Shelby replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
