Activity Forums DaVinci Resolve Opacity Settings
  • Opacity Settings
    Posted by Chris Martin on March 6, 2012 at 3:07 pm
    I read in manual that opacity settings ported over from an xml are non-adjustable, but will Resolve allow for changing opacity settings based on a 100% starting point. I only see a menu for changing composite mode but no opacity parameters but wanted make sure it was not hiding somewhere else.
    Cheers, Chris
    Robert Arnold replied 13 years, 10 months ago 3 Members · 2 Replies
  • Gabriele Turchi
    March 6, 2012 at 4:28 pm
    as far as i know is not possible …
    i asked them couple of times to add this feature , would be great control the opacity of the layer …
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
  • Robert Arnold
    November 8, 2012 at 12:30 am
    Just learned how to do this from another user on this forum!
    1. Right-click in the node area and choose Add Alpha Output. A new gray rectangle will appear at the right.
    2. Add a serial node and drag its matte output (the blue triangle) to the Alpha Output rectangle.
    3. Use the Output Gain on the Key tab to control the opacity of the layer.
    This is a huge help. Thanks to Brandon Thomas.
