Activity Forums Adobe After Effects Expressions Opacity ON/OFF expression
  • Opacity ON/OFF expression
    Posted by Sregier on July 24, 2007 at 5:25 pm
    I have an animated character that has a separate layer for eyes closed in order to blink. I want to use an expression that would randomly bring the opacity of this layer from 0 to 100 and back down, in order to simulate blinking.
    There must be a simple expression for this. Any ideas?
    Greg C neumayer replied 6 years ago 6 Members · 6 Replies
  • Lord Scales
    July 24, 2007 at 11:39 pm
    Weel, this expression will not offer you many control, but try this Dan Ebberts script (I changed it for work in Opacity):
    holdTime = .5; //time to hold (seconds)
    seed = Math.floor(time/holdTime);
    seedRandom(seed,true);
    Math.round (random())*100
    More info about the script in: https://www.motionscript.com/mastering-expressions/random-1.html
  • Craig Wall
    July 25, 2007 at 7:35 am
    There are many more qualified to answer than me, but I’ll give it a shot.
    You would use a wiggle expression.
    You would set a very low frequency…so that your subject doesn’t look like he/she’s enduring an epileptic fit.
    As I understand any value returned that exceeds 100% would still equate to 100% which could work to your advantage…(The opposite would be true, I believe a negative value would return 0) You could use simple multiplication or division to push your opacity to the two extremes 0 and 100.
    Alternatively I wonder if you can wiggle a hold on and off.
    Here is an adjustable/very flexible wiggle expression
    tweak this…
    wigfreq = 30; //wiggle frequency
    wigamt = 30; //wiggle amount
    wigdetail = .025; //detail of noise
    wiggle(wigfreq, wigamt, wigdetail)
    What I have provided but stick around and someone will give you a more succinct and more refined answer.
  • Lord Scales
    July 25, 2007 at 6:06 pm
    Maybe it would be better to create a Checkbox (Effect > Expression Controls > Checkbox Control) and create this expression for the eye’s opacity:
    if (thisComp.layer(“Blinking control”).effect(“Checkbox Control”)(“Checkbox”) == 0) 0 else 100
    Animate the Checkbox to get the blinking effect.
  • Bruno Meira
    March 14, 2012 at 12:22 am
    its possible to do that with slider control? for control multiple comps? thanks!
  • Jay Mueller
    November 9, 2016 at 2:35 pm
    Thanks. This works great for turning on and off render intense layers will setting up the comp.
  • Greg C neumayer
    August 21, 2020 at 10:57 pm
    This is a pretty old post, but still valuable for expressions. Here’s a script get something to flicker/blink.
    If you put the opacity at 50%, it will randomly blink on/off.
    If you put two keyframes from 100 to 0%, it will transition with flickering instead of a smooth fade, like a light burning out.
    If you don’t use any keyframe and set the opacity to 70%, with a flicker frequency of 100, it nicely approximates an eye blink.
    Cheers!
    -Greg @ Antifreeze Design
    //--Flicker On
    //Make something flicker to 100% opacity instead of fading in
    //Adjust this flicker frequency to your taste
    flickerFrequency = 150;
    op = value;
    if(op > 0 && op < 100){
    reverseAmt=100-transform.opacity;
    wiggledAmt=wiggle(flickerFrequency,reverseAmt);
    roundedAmt=Math.round((wiggledAmt/100));
    roundedAmt*100;
    //--end Flicker On
