Activity Forums Adobe After Effects Expressions Opacity of Layer 1 driven by Position of Layer 2
  • Opacity of Layer 1 driven by Position of Layer 2
    Posted by Johnnyfix on April 29, 2007 at 11:25 pm
    THis might be a no brainer, but I can’t seem to find a solution of my own.
    Okay, I have a column of ‘buttons’ that I have pushing forward in z-space. Their forward movement is being driven by an expression that affects tthe each button layer based on the proximity of a null.
    I also have a text layer for every button. each text layer is parented to the position value of it’s respective button layer.
    What i want is acheive is a set up so the text’s opacity shifts from 0 to 100 as it’s parent button layer is offset in z space, then back down to 0 as the button returns to it’s original position.
    Put another way: when button’s Z value is 0, then text’s opacity is 0,
    but when button’s value is 30 (or possibly 60), then text’s opacity is 100.
    I hope this makes sense. Any help or ideas would be awesome. Thanks!
    Lord Scales replied 19 years, 4 months ago 2 Members · 3 Replies
  • Lord Scales
    April 29, 2007 at 11:37 pm
    [johnnyfix] “Put another way: when button’s Z value is 0, then text’s opacity is 0,
    but when button’s value is 30 (or possibly 60), then text’s opacity is 100.”
    I would do:
    x = thisComp.layer(“name”).transform.position[2]
    linear (x, 0, 30, 0, 100)
    So, as the value of “x” changes from 0 to 30, the opacity changes from 0 to 100 in a linear interpolation.
  • Johnnyfix
    April 30, 2007 at 12:22 am
    Thank you so much.
    This works perfectly.
  • Lord Scales
    April 30, 2007 at 12:36 am
    You are welcome!
    There are some variations of it:
    ease (x, 0, 30, 0, 100)
    easeIn (x, 0, 30, 0, 100)
    easeOut (x, 0, 30, 0, 100)
    In ease, when the value of x is 0, the velocity is 0 and when the value of x is 30, the velocity is 0 also.
    In easeIn, when the value of x is 30, the velocity is 0 and in easeOut, when the value of x is 0 the velocity is 0.
    Lord Scales
