Activity › Forums › Maxon Cinema 4D › Opacity Keyframe?
Opacity Keyframe?
Posted by Subspecies on December 18, 2006 at 5:17 pmhi all,
is there something similiar to the opacity keyframe in After Effects?basically fading an object on and off?
often i use the “visible in editor / visible in render” keys, but that doesn’t always work so well…
any help is appreciated…
sajjad abouei replied 3 years, 10 months ago 10 Members · 9 Replies -
Mylenium
December 19, 2006 at 6:59 amYou can add a visibilty track in the timeline. If that doesn#t work for you, then you will manually have to keyframe the material channels. You can anaimtae the transparency, but because in CG even transparent objects can have specular highlights, you’d have to animate that, too.
Mylenium
[Pour Myl
Chris Smith
December 24, 2006 at 5:46 amIf you turn on the alpha channel and animate white to black I’m thinking that should do it. Should take care of specularity and all the other channels (I think, but worth a try).
Chris Smith
https://www.sugarfilmproduction.com -
Anthony Caruso
December 18, 2008 at 8:00 pmSelect the object, then go to Tags > Cinema 4D tags > Display. In that tag window check the Visibility option and change the value there…..I just discovered this today.
Adam Trachtenberg
December 18, 2008 at 10:14 pmI hope Dante hasn’t been waiting two years for that answer. 🙂
sajjad abouei
October 19, 2022 at 2:57 pm14 years later and this helped me!
Just for those you wonder why it doesn’t work, it works not in viewport but in the render
for viewport use a material with color in alpha channel (make that color gray)
