Activity Forums Boris FX opacity keframes backwards
  • Matt Mullen
    April 1, 2010 at 6:33 pm
    Can I see a screen shot?
    did you make sure your import settings are set to Layers ‘Step Upwards’ ?
  • Matt Mullen
    April 1, 2010 at 6:37 pm
    Sorry,
    Didn’t see these screen grabs posted.
    I’ll let you know.
  • Matt Mullen
    April 2, 2010 at 4:24 pm
    The only thing that might explain the differences is you are not on the latest.
    Can you double check the version by navigating to /Library/Application Support/Adobe/Common/Plug-ins/CS4/ and getting info on the XML transfer bundle.
    Let me know what version it says.
    -Matt
  • Dustin Ward
    April 2, 2010 at 5:06 pm
    1.0.1.2
  • Matt Mullen
    April 2, 2010 at 5:11 pm
    The latest is 1.0.5, should resolve your problem.
    Grab the update from our updates page:
    https://borisfx.com/updates‘>
  • Matt Mullen
    April 7, 2010 at 7:09 pm
    Dustin,
    Just want to check in.
    Did updating resolve your issue?
  • Dustin Ward
    April 7, 2010 at 7:13 pm
    Thanks for checking. I haven’t started another project yet that involves this issue, but it most likely fixed it because it was listed in the updates. I’ll let you know next time I use it.
  • Matt Mullen
    April 7, 2010 at 7:27 pm
    OK, sounds good!
Page 2 of 2
