Activity › Forums › Adobe After Effects › Opacity frustrations
Posted by Alan Smith on October 26, 2009 at 11:09 pmHow come in Aftereffects, if you put two black solids on top of a white background and set both their opacity to 50%, you still get a 50% opacity black?
Surely you would expect that two identical 50% opacity layers on top of each other should give you a 100% opacity result, no?
Does this bug anyone else or is it just me?
Alan Smith replied 16 years, 10 months ago 5 Members · 5 Replies -
Danny Winn
October 26, 2009 at 11:50 pmActually it makes perfect sense. You’re asking for 50% of each Black Solid and that’s what it’s giving you. If you want 100% then just keep the one Black at 100%. I don’t get it:/
What exactly are you trying to do with all this?
Xinlai Ni
October 26, 2009 at 11:51 pmopacities are not additive, if you will, transparencies are multiplicative:
Your set up has two black layers with opacity 50%, that’s the same as saying they both have transaparency of 50%, which means if you overlay them they have a transparency of 50%x50%=25%, which means 75% opacity.
The fact that transparencies are multiplicative can be justified by thinking of rays going through these layers, after the first layer, 50% of the original light passed through, and after the 2nd, 50% of the 50% passed through.
Hope this helps.Xinlai Ni
Software Engineer, Google Inc. -
Harry Frank
October 27, 2009 at 4:12 pmIf you want the Alphas to add together, set the blending modes to “Alpha Add”
Harry J Frank
Freelance Motion Designer
graymachine.com -
Todd Kopriva
October 27, 2009 at 5:06 pmXinlai and Harry have it.
Here’s an excerpt from the Alpha Add section of the blending mode reference in After Effects Help:
“When two areas of 50% transparency overlap, the result is not 100% opacity but 75% opacity, because the default operation is multiplication. (50% of the light gets through one layer, and then 50% of the remainder gets through the next layer, so 25% gets through the system.) This is like partial transparency in the real world. But, in some cases, you don’t want this default blending. You want the two 50% opacity areas to combine to make a seamless, opaque join. You want the alpha values to be added. In these cases, use the Alpha Add blending mode.”
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Alan Smith
October 30, 2009 at 11:30 amGreat thanks for the replies
Yep 75% makes complete sense.I just naturally assumed that transparencies were additive and got frustrated when doing cross fades and the mid point was still transparent.
Thanks for the help.
