Opacity fades & displacement of objects
I occasionally use Premiere Pro CS5 with Windows 7-64.bit-pro on old Standard-Def video projects that need an update. One little issue that bugs me is the following…
When I have a small floating object, Luma-keyed over an SD static graphic, I sometimes make it fade out with the Opacity control — instead of just ending the object’s clip on the timeline. It works OK, but there is always a small positional displacement of the “floating” object that is just barely noticeable.
Is there a cure for this – has anyone else noticed this?
