Activity › Forums › Adobe After Effects Expressions › Opacity fade in and out with marks
Posted by Marcelo Cabral on March 12, 2013 at 6:02 pmHi
I am working in a simple project and I need to make opacity fades in and out but using marks in the layer. First mark for the fade in and next mark for the fade out. Thanks in advance.Marcelo Cabral replied 9 years, 3 months ago 4 Members · 12 Replies -
Dan Ebberts
March 12, 2013 at 6:30 pmSomething like this maybe:
fadeTime = .5;
if (marker.numKeys > 1){
t1 = marker.key(1).time;
t2 = marker.key(2).time;
if (time < (t1+t2)/2)
ease(time,t1,t1+fadeTime,0,100)
else
ease(time,t2-fadeTime,t2,100,0);
}else
value
Dan
Marcelo Cabral
March 12, 2013 at 7:15 pmThank you Dan!! it works awesome. That was I was looking for. Best regards.
Marcelo Cabral
March 12, 2013 at 7:49 pmHi Dan, me again.
I have this expression to move in and out of the scene a text layer. It works fine but It would be even better with a ease in and ease out controls. Is this posible? Thanks in advance.m = 450;
if (marker.numKeys > 0 && time <= marker.key(1).time){ value + [1,0]*(time-inPoint)*m; } if (marker.numKeys > 0 && time >= marker.key(1).time){
value + [1,0]*(marker.key(1).time-inPoint)*m + [0,0]*(time-marker.key(1).time)*m;
if (marker.numKeys > 1 && time >= marker.key(2).time){
value + [1,0]*(marker.key(1).time-inPoint)*m + [0,0]*(marker.key(2).time-marker.key(1).time)*m + [1,0]*(time-marker.key(2).time)*m;
Mitch Mann
March 12, 2013 at 8:53 pmCool, I didn’t know you could do Eval’s in expressions, I’m going to try that. Thanks Dan!
Dan Ebberts
March 12, 2013 at 9:30 pmHmmm… I think to do that the expression needs to be able to calculate the distance traveled over a specific interval, and then use ease(), easeIn(), or easeOut(), as appropriate. The way you have it set up, the expression could calculate the distance of the travel up to the first marker, but there’s no fixed distance traveled (or fixed interval) after the second marker–it just keeps going. Maybe with 3 markers…
Dan
Juanluis Vich
May 18, 2017 at 5:32 pmhi!
on your expression:
fadeTime = .5;
else
}else
value
what if we add another “in” marker in the layer later in the timeline?
how it could be modified to have it fading in again? (so basically each time it reaches the “in” it fades in and “out” it fades out, not only the first timethanks!
Dan Ebberts
May 18, 2017 at 5:58 pmSomething like this might work:
fadeTime = .5;
if (marker.numKeys > 0){
n = marker.nearestKey(time).index;
if (time < marker.key(n).time) n--;
if (n > 0){
t0 = marker.key(n).time;
if (n%2)
ease(time,t0,t0+fadeTime,0,100)
else
ease(time,t0,t0+fadeTime,100,0);
}else{
0
}else
value
Dan
Juanluis Vich
May 18, 2017 at 7:17 pmawesome!!!
this way every marker will trigger the in and out fading, right? I don’t know if it is possible to make it work only if the comment “in” or “out” appears? to prevent any unwanted in/out, I mean…
Dan Ebberts
May 18, 2017 at 7:50 pmThat’s trickier, especially if it’s possible that the expression could run into a marker that doesn’t have “in” or “out”. It would have to loop back through previous markers to figure out what state it should be in currently.
Dan
