  • Posted by Sebastian Martinez on September 5, 2007 at 1:18 pm
    Hi guys,
    I’m very fresh on expressions and had a look all over the place for a simple thing: I am linking the opacity of one layer to another via the pick wipp so that they start fading in on the same frame. So far so good. But what I want now is that the linked layer should fade in slower than the other. How is that possible in the expression?
    Probably a very short phrase but my java skills are too poor yet – a little tip would help!
    Ta!
    Sebastian
    Sebastian Martinez replied 19 years ago 2 Members · 3 Replies
  • Mike Clasby
    September 5, 2007 at 4:48 pm
    delay = 5; //number of frames to delay
    op = thisComp.layer(“Leader”).opacity;
    d = delay*thisComp.frameDuration;
    op.valueAtTime(time – d)
  • Mike Clasby
    September 5, 2007 at 4:49 pm
    I just had a Copy/Paste malfunction, here is all of it.
    This expression on Opacity should do what you want (Copy the expression, Alt-click the opacity Stopwatch, Paste, then click outside the expression box):
    It assumes the first layer you made is named “Leader”, change the “Leader” in line 2 to whatever you leader layer is named. Actually line 2 should be what you had after the pickwhip you did, except with your layer name, and we made it a variable.
    This expression was reassembled (hacked) form a Dan Ebberts expression from here:
    https://www.motionscript.com/mastering-expressions/follow-the-leader.html
    Those expression are fro trails so they use index-1 which goes off their stacking order, but the expression above will work in any layer arrangement or order.
    Dan’s site is fantastico:
  • Sebastian Martinez
    September 6, 2007 at 2:08 pm
    Wow, that works! Like a swissmade watch – nice. That worked IN KIND of they way…
    More persize now: The “leader’s” opacity from 0 to 100 within a frame. The follower should start it’s 0 % opacity from the same spot but reaches the 100% continuously after the delay of 5 frames or whatsoever.
    Jese, that was a big lesson anyway! Thank you yikesmikes for your instant help. Ikind of understand and “read” that syntax – I just tried with more of big dan’s stuff but with not much of usefull results. I guess it’s just a language thing.
    Dan’s webpage is a great indeed! I have visited it a few times before. Before I posted that message I tried a few expressions from the very same link where you “cracked” your sugestion from.
    But thanks so far big time!
    Seb
