Activity Forums Adobe After Effects Expressions Opacity change at markers
  • Opacity change at markers
    Posted by Alex Dinnin on January 22, 2008 at 1:36 pm
    Hi All,
    I am trying to set up a composition that people in my office are going to use again and again..
    what I need to do basically is.. have a layers opacity change every time it passes a marker…
    so at marker 1 it is 100% marker 2 0% marker 3 100%
    The problem I have is they need to be Hold Markers.. so there is no transition..
    So I can move the markers and the opacity follows them..
    ***edit*** actually whilst trying to work this out myself.. referencing comp markers rather than layer markers would be easier !!!
    I hope this makes sense..
    any help would be greatly appreciated
    regards
    Alex
    Filip Vandueren replied 18 years, 8 months ago 2 Members · 3 Replies
  • Filip Vandueren
    January 22, 2008 at 2:25 pm
    Well, you can only have 10 comp-markers…
    here’s the expresso for layermarkers (apply to opacity):
    if (marker.numKeys) {
    // what's the nearest marker ?
    nearest_marker=marker.nearestKey(time)
    // if the nearestKey lies in the future,
    // subtract 1 to get the index of the 'current' key
    current_marker_index = 1 + nearest_marker.index - (nearest_marker.time > time);
    // convert our running marker index to
    (current_marker_index%2)*100
    } else {
    // degrade nicely if there are no markers:
    value;
  • Alex Dinnin
    January 22, 2008 at 3:27 pm
    Thanks for replying
    I have applied this to the opacity.. and it doesn’t seem to do anything ??
    is this for cs3 or can it be applied over all versions ?
    Alex
  • Filip Vandueren
    January 22, 2008 at 5:17 pm
    I only have CS3 installed right now.
    There were some bugs in the marker expressions for the previous versions of AE, but I believe they only had to do with not being able to access the name/text of a marker.
    Let’s debug:
    First of all: the expression looks to markers on it’s own layer.
    Try this on a layer without markers:
    if (thisLayer.marker.numKeys>0) {
    50;
    } else {
    0;
    Is your layer at 100, 50 or 0 % ? -> it should be 0%
    Add a marker, -> it should be 50%
    If that worked, then try changing the first line of the previous expressions to:
    that might help.
